Converter NL/ML
Hello,
Converter between Moment and BeoVision is interrupting the signal on regular basis. System may work for an hour and then  signal interrupts. Converter worked nicely for for two years, during the time Moment was send for repair five times (most often the reason was problems to keep wifi connection of Apple network). Now the Moment seems to work but converter not.
Could reseting resolve the problem? Can resetting be made without loosening all of the settings of the converter?
Hi, the dropouts of the converter are caused by the latest software update of the Moment. I experience same issues and there is a threat on the forum where it is discussed.
I’m in the process of requesting a software rollback to the previous version. Contacted B&O support and awaiting the pushback to my Moment.
