Controlling NAD T585 PUC
Hi
Had and old NAD T585 DVD/CD player in the attic, and wanted to connect it to my Beovision 11 as I would like to listen to my old CDs again. Especially my Classic albums. They are hard to find in Apple music. Connected the NAD via S/P DIF and it sounds great, but.... I can only find NAD T557 in the PUC table, and it will not do the trick.
Has anyone solved this? Maybe another brands PUC codes can control the NAD?
These NAD products use the same IR codes as the T585: T535, M55, DVD section of L54, Viso Two, & Viso Five.  If the T557 is the only NAD player in the PUC table, you may be out of luck because their previous(?)  Blu-Ray player, T587, used different codes from the DVD players.  (This according to NAD's "NAD-universal" remote control (SR8) document.  Sorry, not what you asked, but maybe it'll help you search.)
Hi Trackbeo
Thanks for your reply. I think I will have to do the skipping of tracks the old fashion way, getting up from the sofa and push the button :-)
