Controlling Humax Foxsat HD from BV8-32 via STB
Hi everyone,
Apologies for the daft question 😳 I'm trying to get my BV8-32 to control a Humax Foxsat HD satellite receiver and I can't seem to get any control of this at all via the PUC options listed on the BV8 menu.  I suspect that I need to get the STB table updated so that the Foxsat is specifically listed, but usually in the past I've had some measure of contorl by selecting a similar product from the same brand of STB in the PUC list.  Not this time! 😕
My BV8-32 is at STB table version 03.90a and it has a number of other Humax products listed (just not the Foxsat HD).  I'm guessing that the only way forward is an STB table update?
Any ideas? Thanks,
Steve.
Steve,
I've taken advantage of the Lintronic website in the past to compare coding on different STBs. It might be a way to prove that the Foxsat is completely different from what you might think are similar models (or if you are very lucky, to find another STB in your current PUC list that shares some command codes.)
Graham
Thanks Graham,
That's good thinking!  Will have a look there later on, if I find anything useful I will share it on the forum.
Kind regards,
Steve.
HUMAX FOX SAT HDR is in the latest PUC  table from B & O.
I can confirm this as well because the engineer updated my beo 7 40 mkiii with the latest 10 software yesterday and the required PUC for my foxsat HDR and it works fine.
Thanks Guys!
I knew someone would have the answer!  Very grateful for all your help 🤒
Kind regards,
Steve.
