Controlling BeoSound Essence MKII with Beo4 or BeoLink 1000
Sorry, Here's the IR mapping one.
1. the settings of your BLC seems OK.
2. but the Essence has to proces the commands. And it uses the same sources (Cd. ATape....) as you set in the BLC.
3. Do a test: set N.Music in the BLC as CD of the BS5500? Or even more extreme, use V.Mem or DVD and see what happens.
Hi Carolpa. None of it seems to make a difference. Just to be sure, should the ML role be set to VMaster or Source Center?
