I have an IR eye connected to my BeoSound Essence MKII. Join works, volume also works both via my remotes (Beo4 and BeoLink 1000) and the volume buttons on the IR Eye.
The problem is with the source buttons.
What I would like:
Press CD: CD (NL source)
Press Tape: Tape (NL source)
Press PHONO: Phono (NL source)
All of the above sources come from my BeoSystem 5500 + Datalink ML converter + ML/NL Convert and work well if I select them from the app. However if I use the source buttons on my remote I get the following:
Press CD: Spotify starts
Press TAPE: Deezer starts
Press PHONO (Which is the same IR signal as N.RADIO I believe): TuneIn starts
How can I fix the coupling of the source buttons?
