I have a Beosound 9000 and have it connected to a set of 8000 speakers. A little while back the remote stopped working and many trials have led to the position that the IR receiver board has failed on the 9000.
The 8000's are connected to the 9000 powerlink out plugs.
Yesterday I acquired a Beolab 3500 Mark 1 and have connected this directly to the 9000 using the ML cable.
With the 3500 only plugged in, the manual volume buttons on the 9000 don't work anymore, but I have full functionality of the 9000 via the Beo4 using the 3500 as the IR interface. Great. Finally able to operate by remote.
But then I plug the 8000's back in and I cannot control the volume of the 8000's from the remote. I can manually adjust volume to the 8000's from the 9000 buttons, but this does not alter the 3500. So basically I can control the 3500 volume and the functions of the 9000 from the remote, but I can not alter the volume of the 8000's.
Reading the manual for the 3500's and the 9000 it appears
that it is possible to run the three speakers and 9000 in the same room, but I
don't know how to program the remote to do this.
I've tried a number of options on the 3500 using the L.Opt settings on my Beo4 remote. 5 and 6 will not operate the CD player at all, but 1 through 4 operate all functions of the CD player except the volume of the connected speakers.
I've seen a 3500 setup to a 9000 via ML before and the 3500 was able to control the main room speaker volumes, even though in that case the 3500 was in another room.
One issue I'm going to have is that I can't talk to the 9000 via remote so I have no way to set that into any other mode. Could this be the issue? Any way to set the 9000 into a different mode using on board controls?
Can you offer any help please.
