Control Xbox 360 from Beo4/BV7?
I have an XBOX360 connected to my BV7 through HDMI, usually I use the setup for gaming but I have begun to watch movies through the XBOX Zune rental movie service. So I was thinking if it's possible to use the Beo4 remote instead of the ugly xbox one?
I'm still new to the "B&O way" so I'm guessing that I either somehow program my Beo4 or use the IR-thingie from the BV7, but the big question is how am I suppose to do?
Have anyone done a setup like what I have in mind?
You should use the "IR-Thingie" 😕
Connect the cord to one of the PUC sockets on the back of your BV7. Attach the IR transmitter in the other end of the cord on the Xbox IR- eye.
Go into the menu of the BV7 and select the input you have for the x-box. There you should be able to select "PUC". When you have done that you will be promted to select the XBOX from the list that appear (provided you have the XBOX codes loaded when the set was installed).
/C
Nice, I talked to my B&O dealer and they could assist me with the xbox360 codes to the BV7.
Will update later with my experiences.
The techie loaded the xbox 360 codes into my TV and connected the PUC (earlier IR thingie ;) ) and I would say it works really well.
But where can I find what button on my Beo4 is mapped to?
For example havent I figured out how to fast forward/backward in a movie?
I thought that would work in a similar way as on the buildin DVD on the TV.
My friend Google couldn't even find anything so maybe someone here cold help?
Call your dealer again.  they have the ability to print you or email you a remote layout sheet for any PUC codes.
I think what you want is below
Oh, so sweeeet!
Thank you Keith!
