Hi
I am thinking of getting a new LG oled55e6v, currently I have BV11 40", but I want to keep my Beolab 9 speakers.
So the question here is rather simple, can I use LG optical out along with connection HUB, and be able to regulate volume using the original remote?
My thought was to use an optical cable from TV -> Connection HUB -> BL9, or find some kind of other smart solution, as simple as possible in other words.
I don't want to occupy the headphone out, I use those a lot.
Update: 20-12-2016
I just came to think of the HDMI-ARC output on the LG tv. If I could find a pre-amp which supports HDMI-ARC input, and give variable line out, then BL9 could be put into Line mode. So if anyone here has some ideas in that regard, I am all ears.
Update: 21-12-2016:
I wrote to Lindy in UK and got this answer - which might alse be a possibility.
Currently the only ARC enabled product we stock that allows for volume control would be our Part No. 38092:
https://www.lindy.co.uk/audio-video-c2/converters-scalers-c105/hdmi-arc-dac-converts-hdmi-arc-to-analogue-audio-p8280
This will allow you to use the Audio-Return-Channel HDMI port on your TV to send audio out via L/R Phono to your speakers. You should then be able to control the volume with your TV's remote control. We have tested this with Samsung TVs however I could not confirm if it would work in the same way on an LG TV.
