Connection hub w. BL9 + optical out from LG?
Hi
I am thinking of getting a new LG oled55e6v, currently I have BV11 40", but I want to keep my Beolab 9 speakers.
So the question here is rather simple, can I use LG optical out along with connection HUB, and be able to regulate volume using the original remote?
My thought was to use an optical cable from TV -> Connection HUB -> BL9, or find some kind of other smart solution, as simple as possible in other words.
I don't want to occupy the headphone out, I use those a lot.
Update: 20-12-2016
I just came to think of the HDMI-ARC output on the LG tv. If I could find a pre-amp which supports HDMI-ARC input, and give variable line out, then BL9 could be put into Line mode. So if anyone here has some ideas in that regard, I am all ears.
Update: 21-12-2016:
I wrote to Lindy in UK and got this answer - which might alse be a possibility.
Currently the only ARC enabled product we stock that allows for volume control would be our Part No. 38092:
https://www.lindy.co.uk/audio-video-c2/converters-scalers-c105/hdmi-arc-dac-converts-hdmi-arc-to-analogue-audio-p8280
This will allow you to use the Audio-Return-Channel HDMI port on your TV to send audio out via L/R Phono to your speakers. You should then be able to control the volume with your TV's remote control. We have tested this with Samsung TVs however I could not confirm if it would work in the same way on an LG TV.
There is a long thread about the hub here:
/forum/general-discussion-and-questions/new-beoplay-connection-hub
N.B. Do remember, that you will have no center speaker option this way!
Thanks, did see that thread but it seems to continue endlessly.
That LG model has its own build in speaker / soundbar - probably not as good as B11 - but still to the better.
I tried the connection hub with optical out from a Samsung tv.
I set the Samsung to give sound through optical and programmed the connection hub to adjust volume from the Samsung remote.
So yes, it should work.
The additional speaker/s in the tv does not make it a center speaker.
That is what the audioengine in your BV11 is for.
Either it 'upmixes' from a stereo source to 3.0 - or it presents a dedicated center signal according to your settings as the center channel - for better understanding of especially spoken words/dialog.
Soundwise this would be a downgrade from your current setup.
However, if your preferences are picture - size and (maybe) quality - it might be the way to go.
A friend of mine also uses this solution but says he gets loud pops from the Connection hub when optical source is changed. I think this is a problem with the hub but maybe limited to his case only.
I can only speak for the Samsung soundbar (8.1), and I would prefer my Pentas over that one.
I misunderstood your post, MM.
The pros and cons are quite difficult, I really wish it was more easy. I love b&o, make no mistake, have had b&o tv since beovision 3, but the picture on those new oled is jaw dropping and extremely desireable.
But I might go down the route and try out the connection hub along with it.
I guess a lot of the beoworlders will be interested in hearing about your experiences (if you go that route), so please keep us posted.
