You could connect it to a BeoSound Core, which in my opinion is a solid product and even better with an Essence remote if you want to stay with B&O’s system/app or AirPlay 2, Chromecast etc. If you just want to attach your speakers for a good solid AirPlay 2 wireless streamer then you can get a 2nd gen AirPort Express. You will need an adapter. The AirPort Express is around $50 on eBay. If not, you can use something like the BlueSound Node 2i.
I have all three and my preference is for the Core because it has a slightly better SQ (since I use it’s DAC processing) but not much. It is rock solid in my experience. The Node 2i is also good buy slightly more bulky and at a similar price as a Core doesn’t offer any extra benefits. It’s great if you want to connect them to non active speakers so you won’t be using it’s amp for the BL 18.
