Connecting Playmaker
UPDATE. The problem of Playmaker dropping out regularly has been solved! I have a new BT Home Hub 3 (Version B) which works flawlessly with Playmaker. My previous BT Home Hub 3 (Version A) was the problem. The problem was only with Playmaker though, as it functioned perfectly with Apple TV using Airplay.
After advice from my B&O dealer, I contacted BT who sent the new HH3(B). So, anyone with a BT HH3 who is having problems should check which version it is.
I would like to add how pleased I am with the sound quality and ease of use of the Playmaker. I am so happy with it that I am seriously considering selling my BeoCenter 2.
Thanks to all who offered suggestions and advice.
djs
That is great - enjoy 🎵
But please consider keeping your BC2 - you can easily connect the Playmaker to the A.AUX of the BC2.
Greetings MM
Vince,
To confirm whether your HH3 is A or B, go into settings at
Many thanks for thisI have a b version but my Pm is connected over power line which dropouts even though the signal on the pm is whiteIs yours directly connected to bthh3?ThanksVinceVince, To confirm whether your HH3 is A or B, go into settings at http://bthomehub.home . You will need your password of course. Hope this helps. djs
Vince,
My Playmaker is connected to the HH3 by Ethernet.
djs
As the original poster of this thread, I have to report that I have given up on Playmaker and packed it away.
I did have initial success when BT supplied me with a new HH3 (version B). Although I no longer had the issue of losing the connection, I did start to experience dropouts. The dropouts would only be for a few seconds but due to the regularity of them I soon grew tired of them.
I want to make the point that my Apple TV works flawlessly. So, to say that the problem is the HH3 cannot be entirely correct. I don't understand why the Apple TV works with Airplay and HH3 but the Playmaker doesn't.
djs
Has anyone had similar issues with the Playmaker and a BT Home Hub? Any advice about the best course of action would be appreciated.
The Playmaker right royally gets on my t*ts, I can tell you :)
I bought a MKI a couple of months ago and was quite to open a thread saying how good it was and how the sound quality was ace compared to my Airport Express. Still believe this to be the case. Sound quality is superb.
However, one area where the Airport Express excels over the Playmaker, is Airplay connectivity. The Airport Express, in the same setup, in the same room, about 5 metres away from my Apple Time Capsule, never (!) loses the connection. The Playmaker loses the connection, nearly all the time often for 20 seconds at a time. Sometimes it disappears from Airplay altogether.
I've tried my Netgear router, gone back to the Time Capsule, manually setup a wifi channel, set the channel to automatic, but it's still the same.
As a comparison, the BS8, connected to an Airport Express, downstairs, many metres from the Time Capsule, never loses the connection. It's definitely a Playmaker issue.
This week I'm going to buy a power socket solution and connect via ethernet, see if this makes a difference. I'll report back.
