Hi
Is there an easy way to connect a IPOD directly to a beolab 2000. I was thinking of connection a converter 1611 to the beolab and then via the audio/aux port on the converter connect it to the IPOD. But is there a masterlink to IPOD cable?
Mogens
Hi
Mogens
No, you need an audiomaster. iPod connects to audiomaster and audiomaster connects to BL 2000. If audiomaster don't have ML but MCL you'll need the converter.
