My new set up is a Beovision 4.42 / Beosystem2 for video and a Beosystem 2500/Beolab2500 in one (bed)room.
I want to set it up as one and using beo4 as ab.
The Beolab2500 speakers are connected by PL to the Beosystem2 and this works fine with the BV4 on, the Beosystem2500 audio is connected over T611 by using a ML cable to the BV4 and a din7 cable to the Beosystem2500.
All seems to work fine; all beo4 commands are working just fine except for one thing; the sound is awfull when using CD or Radio (TV sounds is perfect) very high toned distorted misformed sound.
Do I have to use an additional PL cable between T1611 and Beosystem2500? or is there another issue at hand?
I assume a T1614 won't work with the BS2500?
Hope someone will be able to help me out here, thnx.
