Connecting BL11 / BL8000 to BV5
I just tried to connect the BL11 over PL.
Unfortunately, the BV5 menu does not allow me to turn on only the subwoofer. Only after setting frontspeaker to some BLs, I cano activate the sub. I an leave the rears as "none".
Given I don't have fronts connected, I assume that the BV5 now ouputs "center" (1.1) and no longer "stereo" (2.0)? is this assumption correct and does it make any sense for me to run the TV this way? How would you rank 2.0, 1.1 and 3.1.
If I were to connect BL8000 to the BV5 as fronts, would I connect them directly to the TV or to the BL11? Why does the BL11 even have PL output?
Hi Steve
I recall when the BeoLab 11 sub-woofer was launched it was suggested to be paired with BeoLab 4000 or BeoLab 6000. It's not a hugely powerful sub and you may find that even when set up, it doesn't improve the sound with Lab 8000's.
I performed a number of home demonstrations when the "Tulip" was launched and even though several clients were primed to purchase, once they heard it with their existing set up, they couldn't justify the expense.
Good luck
Opman
Thanks for your reply. No chance to have the BL11 support by BV5 (without fronts)? This should help the BV.
Also, if I were to try out with fronts, how would I set cable cables required (1) BV5 with BL3/BL11. (2) BV5 with BL8000/BL11, or (3) M/NL with BL3/BL11, (4) non-B&O TV with BL3/11.
Strange that you say that there it doen’t add anything to the BL8000’sIt’s my setup for the last 10y and I can tell that there is huge difference when the sub is off.
The BL2 and 19 are something completely different. But the BL11 clearly add power to the BL8000... just ask my neighbours...
Karel.
I am definitely with Karel there - a BL11 makes a difference.
Whether this difference is enough for someone can of course be discussed.
f you want to play music with much low synthetic bas content (loud) or when you expect rumble like in the movies from your movies, a BL11 might not be enough.
One should also think of the size of the room for the setup.
Generally spoken, If someone does not notice a BL11 in a setup, it most likely is badly integrated there.
The BL11 has PL outputs because it also can be used with a stereo/2.0 setup from an AudioMaster/System.
In this case you connect the BL11 to the PL out there and use the PL outs on the BL11 for the additional BeoLabs.
You (can) make all settings on the BL11 using the small dip swithes there (please consult the manual).
When used with a tv (with a surround module integrated) you should connect it there as well as the BeoLabs, that will be used as fronts.
Note: on a pre-BSys4 tv/product you can not use the BL11 as a sub without engaging the external speakers in the setup.
All settings/bas management etc is done via the settings of the tv.
Thanks for your messages. I already have a BL11. Bought it some years ago, but never put it in use. I like the design and hope I can now find a way to deploy it.
Thanks for sharing that I cannot use it without fronts with my BV. That's a pity.
I'll likely will buy a pair of BL3, which is a nice set of speakers. Will connect it together with the BL11 either to an ML/NL converter or to a non-B&O television. What cables would I need in either of these two options to make it work? And does it even work?
Connection to a converter will work fine.
You’ll need a PL cable with RJ45/PL connection at one end and DIN/PL at the other - or an adater with an existing DIN/PL cable.
However you will also need the ir-eye for controlling.
As for cables for a non-B&O tv please consult Steve at Sounds Heavenly, who also is a sponsor of this site.
Please describe the connections on that tv in order to know the options you might have there for a connection.
Please be aware, that you might be able to combine both - the converter also has a line-in port, which may be used for connecting the output of the tv.
Connection to a converter will work fine.You’ll need a PL cable with RJ45/PL connection at one end and DIN/PL at the other - or an adater with an existing DIN/PL cable.
I love the idea of combining both non-B&O TV and ML/NL. Isn't there a delay that would prevent TV use? Otherwise, this would be amazing! My TV has a regular line-out (I used to connect it with my A9, which worked). Assume the BL3/11 woudl require some trigger signal though? And not clear how I'd connect the BL11?
What would I need the IR eye for when connecting the BL3/11 to the ML/NL? Assume I'd connect the BL11 and then use the PL-out from the BL11 to connect the pair of BL3?
