Connecting Beosystem 7000/ Beomaster 7000 to Beovision 11-46
Hello,
I have a problem to connect my Beosystem 7000 to my Beovision 11-46 (no/faint sound).
my current setup:
beosystem (Beomaster,Beocord, Beogram, Beogram cd) + Beovision 11-46 + Beolab 20 (wired) + Beolab 18 (Wisa). The speakers are all connected to the Beovision. Controller is Beolink 5000
The Beosystem is connected through a aux/din cable bought at Soundsheavenly.
On the tv the ‘Av’ input is selected but the signal is very weak. I have to cranck up the volume of both bm & bv  before I can hear a weak sound signal. Remarkable is that when I put the Beomaster into standby is that I shortly (1 second or so) have a normal volume output. At the moment I use the headphone jack but now I have a good right signal but a very faint left signal.
In the past I had the same problem and some trial and error with the sound options (option 0,1,2,...) solved the problem. Today I can’t replicate what I did. To be honest I don.t have the best relationship with my local dealer ans Bang&Olufsen online doesn’t seem interested in solving this problem (please contact your dealer...).
I hope one of you guys/girls have the magic solution. This is driving me nuts.
kind regards
Did you consider getting a ML/NL Beolink Converter plus Audio Link Converter 1611? I used this to drive a Beosystem 7000 with a Beosystem 4 (basically the heart of a BeoVision 11)?
Used this will cost you around 400 €...
Ralf
PS: What kind of cable did you get from Steve?
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096 Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55 Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL) Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) Dart Room: BeoPlay V1-40 on floor stand Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I bought this cable.
