Is it possible to connect BeoPlay A6 speakers to BeoSound Moment.
Connecting BeoPlay A6 speaker to BeoSound Moment
If you mean use an A6 (one or more) a a speaker physically connected, the answer is no!
The A6 is not a speaker - it is a musicsystem with builtin speakers.
However, you can easily ‘connect’ the Moment and the A6 in order to share sources (expand, join etc) between both.
This is done over the home network - either wired or wireless.
If you want sound from the BS Moment seperately, you will have to connect speakers/Beolabs - either through Powerlink or WiSA/WPL to it directly.
This aaid, some will maybe suggest connecting the PL-out of the Moment to the line-in of an A6.
Ok, this will be possible - but that will not be my suggestion!
You will run into problems with controlling the sound and the sensitivity, that you won’t have, when you’d connect ordinary Beolabs to the BS Moment.
Thank you so much for your reply.
Can you please expand on your answer because i am not sure exactly what you mean.
I have currently Beolab 18 and Beolab 11 connected wirelessly to the Moment.
Would love to add the BeoPlay A6 to it if possible but has to be done Wirelessly.
Sure, now we know that what you mean is, how to make the A6 part of the same NetworkLink network (B&O multiroom/NL).
Be sure to have both devices on the same wireless homenetwork!
Use the Bang &Olufsen app to see and setup both devices - once that is done, you will be able to e.g. play on one device and ‘join in’ on the other.
Watch this video
Thank you so much much, this is very helpful. I will try it when i get home tonight.
Would you be able to tell me how i can add Spotify to the B&O App. Currently when I press Music on the App it only shows me Deezer and DLNA.
Its unfortunately not possible to add Spotify. The app is built with Deezer only (as Beosound Moment)
Hi
It worked so well with the App, thank you so much. What a relief.
Just one small question.
The B&O App only shows me Deezer and DLNA,.
Is there no way I can add Spotify and Apple Music?
Hi - as already answered by Hiort, you cannot add Spotify to the App, what you can do is to add the A6 to Spotify via the Spotify app but you’ll not be able to share this music flow with the MomentYou can activate Apple Music in the app Configuration/Music pageHi It worked so well with the App, thank you so much. What a relief. Just one small question. The B&O App only shows me Deezer and DLNA,. Is there no way I can add Spotify and Apple Music? Thanks
