I'd be grateful if anyone could suggested a good way of connecting my equipment together, I assume it will mean buying some more kit to do efficiently.
I have recently acquired a pair of beolab 8000s which are currently just connected to an iPad via an auxiliary cable into the line in sockets. Before, I was using a technics amplifier attached to some bookshelf speakers. I have a Beogram 1800 which was plugged into the technics amp (which has a built in pre-amp) but I've not yet connected it to the beolab 8000s.
My technics amp has line out sockets, does anyone know if these are likely to be 'before or after' the volume control on the amp? I assume there's no other way of controlling the volume from the beolabs?
Ideally I'd like a better solution which would allow me to play both records and streamed music through the speakers, could anyone suggest what kit I would need to do this most easily?
Thanks very much your help, much appreciated.
james
