Connecting Beogram 9000 to BeoSound 9000 and keeping Datalink?
Dear people at Beoworld,
I bought a Beogram 9000 record player and connected it to my BeoSound 9000 with a new RIAA amplifier (German brand). It works perfectly and it even though the record player is 18 years old, it still sounds great. Having great fun listening to all the old records from the basement.
It would be even better if I could control the record player with the Beo4 remote, but the new RIAA amplifier that I have now, does not support Data Link. I believe this will only work if I use a original Bang & Olufsen RIAA amplifier that has a 7 pin DIN plug in and out. Am I right?And if so, what type of Bang & Olufsen RIAA amplifier do I need and where could I get it?
If someone here could solve the mystery for me I would be very happy! Thanks a lot!
I am afraid that the BS9000 does not support Datalink so no control of a Beogram by remote is possible. I believe Ridax may be able to offer a solution though. Try a PM to him.
I don't think you will find a B&O RIAA easily either - it would be much easier to add a wire for Datalink - if that were the answer.
Thanks Peter, hope that others can help me further.
Yes, you could remote control the Beogram with my little device at
Hi guy
Need some help, I have a Beosound 9000 Mark 3 with a pair of 8000's. I wish to place the 9000 on the wall so have to change the setting's with some kind of plastic key? Dose any one know where I can find one? I am a keen eBay'er so would prefer not to pay a fortune through a dealer!
James
.....er! Why not tryIck! a screwdriver?
......or a coin, I am sure I did!
