Having received my Beoworld Xmas draw win of Roger Moore's immaculate white BG6500 (thanks Lee!) I want to set it up to run initially through my BC9500. This will save me digging out my BC2300 plus a suitable amp and speakers from various boxes around the house!
I realise that the BG6500 cannot be connected to the PHONO socket because both the BG and the BC's audio stage have RIAA, hence I am planning to connect to the BC9500's TAPE 2 socket as a temporary setup.
My question is this: Do I have to remove the BG6500's datalink pins (6 and 7) to avoid a conflict? Otherwise, when I press play on the Beogram, won't it tell the BC9500 to switch to the PHONO input?
One thing that I am confused by is the circuit diagram for the input stage of BC9500: PHONO pin 6 is connected in parallel with TAPE 2 pin 7 to provide datalink, with nothing connected to TAPE 2 pin 6. However, for the AUX input pin 6 provides datalink.
