Connecting a Humax HDR-FOX T2 to Beovision 7-32
Hi - I apologise for raising a question here which I am sure has been answered before but I was unable to find it on the forum.
My Beovision is about 5 years old and has the HD module fitted. I have connected the Humax STB with both the SCART and HDMI cables to the Beovision and selected from the Connections menu a Humax box at random as the newer HDR-FOX t2 is not listed.  Everything seems to work OK although the HD picture doesn't seem so obviously  better then the SD.  Am I missing something?
did you select source mode ie scart or hdmi
I couldn't see a choice for this but I did have HD and selected DVI-I
try unplugging the scart - do you still get a picture/
Yes - so I guess it is configured correctly for the HDMI.  Perhaps HD on the 7-32 just isn't so obvious.  Thanks for your help wih this.
It is very hard to see a difference between HD- and SD-material on a tv with only 32 inches!
/Räuber
