Dear all,
I am searching for a solution to connect to pre - amps to one set of Below Penta MK3.
One pre-amp is a Beosound 5 that works via Pokerlink.
The other is an analog Yamaha C2x from 1985 to which I also connect met Revox B77 and AKAI GX 650 D Reel to Reel recorders.
I already learned that although the connectors are in the speakers I can not connect them both at the same time.
When I connect OR the Beosound 5 OR the Yamaha sepately all works well. But switching and connectors inside the speaker is not easy and also all the time switching the indicators at the front panel of the speakers is also no good idea as these break very easily after 20 years.
Would anybody know a solution how to do this? I would be very grateful if there is any workable idea. If I have to make it myself its no problem, just I need to know what works.
Richard de Gouw
