Connect passive speakers with multiroom in 2022
What is currently the best way to integrate passive speakers into a B&O Multiroom system?
Now I have a BeoSound Core with several 8002 speakers. Now I want to add an additional room with passive speakers (must be outdoor).
Do I need a second Core and a BeoAmp 2 for this?
Is there any way to make it cheaper than buying these two devices that cost at least 2k€?
So theoretically i can use this configuration to accomplish an additional multiroom with passive speakers?:
BeoSound Essence MKII & MCL2P; connected via PowerLink
BeoLink Converter NL/ML & MCL2P; connected via PowerLink or MasterLink
that should both work?
Either of the 3 - MCL2P, MCL/ML Converter, Beolink Passive - will do.
They are basicly the same, when it comes to acting as an amp.
Do remember that they will need a fully wired/MK3 Powerlink cable in order to turn on/of.
The Beoamp 2 can also be used.
/api/files/437fc088beb24996aafb7e099f68ee76
Just saw that it was already mentioned, sorry
Hi all, have similar question.
i want to connect on mu b&o shape beoamp 2 with boc 86, and then to save some costa War thinking to add beosound passive and make multiroom in  bathroom also.
can someone point me in right direction is this is posibile. Can i control everything with halo.
can i reduce volume in passive, since don’t need to be so loud in bathroom :)
Thail you, all clear :D
