Connect IR-eye plug in to the BS.Core. ?
Jup that is correct!
Doesn’t it need to be a Mark II Core ?
https://bogo.custhelp.com/app/answers/answer_view/a_id/13309/loc/en_GB
According to this there is an IR version of the CORE - so just be careful which one you choose
@ elephant
NOTE! New Mark II of BeoSound Core: BeoSound Core with IR Type No. 3051.
BeoSound Core version without IR type no. 2797. (should now be sold out in DK).
@ chucky
Thanks for your reply.
The question is if it works ? πŸ‘
Peter Pan wrote:
@ chucky
Core 1
Core 2
Yes on version 3051 it does. This serie contains a hardware upgrade of part 1293042
Got the second picture wrong, sorry but it works fine. One note, you need to set it to the right option just like the old beolink active, so 1-6 or 4... otherwise the light on the eye blinks but the Core does not respond.
chucky wrote:
Yes on version 3051 it does. This series contains a hardware upgrade of part 1293042
I wonder if it is possible to order the upgrade ?
Rather than buying a replacement unit !
Hallo chucky
Thanks for your reply. πŸ€’
