Dears,
I recently purchased a Beogram 3500 in order to be able to listen to CD's with my Beomaster 2400. I connected the Beogram to the phono input of the beomaster. Everything seems to work perfectly except that the sound is very loud and there is some distorsion. I searched for information on this forum and I think it is because there is a RIAA integrated in the phono input of my Beomaster 2400, but the Beogram 3500 doesn't need any.
I concluded that I had to connect the Beogram to the Tape input, but this is a 5 PIN DIN socket, so I cannot plug my 7 PIN DIN cable from the Beogram.
==> Is there an existing adaptator cable 7 PIN DIN to 5 PIN DIN?
==> do you have another solution using the phono input?
Thank you for your answer!
