steve1977 wrote:
I am planning to use Twonky to stream my iTunes library using Beimusic app as remote. I currently do not have a NL link ready device, but want to test Twonky first before making the purchase. All my music is in iTunes, so this will be a deal breaker if I cannot get it to run.
1) After installing Twonky, I cannot get see my itunes files. I have manually added below to the twonkyserver.ini file, but also did not work
# full path to the iTunes library .xml file, empty to disable iTunes import
ituneslib=C:\Users\user\Music\iTunes\iTunes Music Library.xml
2) BeoMusic app did not find the Twonky server (not possible unless I have a NL device?). If not possible, what's the best way to trial whether my library can be shared and at a proper speed?
3) Does the Twonky license only come with the Moment or also with Essence or others?
Thanks in advance for your help!
Hi steve1977,
first, yes you can test the Twonky-Server, without having a B&O-Device. Answering your thir question - the lisence for the Server just comes with the BS-Moment - not with the Essence. Lucky you - the license costs you after a free 30 day trial just 19,95 $ - its not robbery, when you think of buying a B&O-Device. 😉
after installing Twonky, open your web-Browser, type in the ip-address of the mac/PC and add :9000 to the address (e.g. 192.168.178.195:9000) and then 1. go to settings/setup and name your Server
2. go to setting/sharing and type in the path to your music like Users\user\Music\ and set the category to music,
3. under devices check - Enable sharing for new media receivers automatically
save changes
4.Go to setting/Advanced start rescan content folders
5. Wait until the scan is done, have a look under settings/status
Now you should see with any DLNA-able Device (e.g. TV, mediaplayer-App....) your server and should be able to listen to your itunes music including your playlists
If you don't, just check other threads about the Twonky-setup in this forum
Cheers Beroli
