Configuring my Beo4 with BV5
I was trying to post this before, but somehow my post got blocked?
I used to be able to play audio-only from my MacMini to my BV5. This worked as the MacMini was attaced to the BV5 mapped to "DVD-2 (DVI)" and I could configure "A.DVD-2" to have audio-only.
Unfortunately, I had to change the mapping to "DTV" and there is no "A.DTV" mapping available with the Beo4. Is there any chance that I can keep the MacMini mapped to "DTV" and still have an audio-only option similar to the non-existing "A.DTV"?
Thanks in advance and hope this post finally gets posted...
You add the AV command to the List.
You press List until AV appears on the display and the press the DTV button, which fires the AV-DTV command.
hfat
