Hello
My set up is: Beosound Ouverture with ML to various rooms. In the same room I have BV 11 and Beolab9,
The speakers are connected via Almando switch. New I would like to integrate Beosound Moment to listen to web radio. I have got ML/NL converter and delay box.
My worries are how to connect and how to setup the system to work satisfying. The remote control should be able to serve the Ouverture, for the other rooms, and the Moment in the living room.
Thank you for any hint.
Regards Ruedi
