For any Beogram 4500 owners out there, could you tell me the clearance height (from the tabletop/surface to the front bottom edge of the turntable) of the front lip of the turntable? Looking to possibly add another Beogram that would live on a pull-out shelf, and want to make sure it'll fit. Given the height of the shelf handle, I think the design of the 4500 might be my best option. Thanks!
Clearance on Beogram 4500
Hi, mine is measured at a height of exactly 26 cm, hope this helps.Kind regards,Rolf
Checked the BG 9500 which is measured at the same height.Kind regards,Rolf
Thanks so much! That’d work perfectly.
