Clearance on Beogram 4500
For any Beogram 4500 owners out there, could you tell me the clearance height (from the tabletop/surface to the front bottom edge of the turntable) of the front lip of the turntable? Looking to possibly add another Beogram that would live on a pull-out shelf, and want to make sure it'll fit. Given the height of the shelf handle, I think the design of the 4500 might be my best option. Thanks!
Hi, mine is measured at a height of exactly 26 cm, hope this helps.
Kind regards,
Rolf
Checked the BG 9500 which is measured at the same height.
Kind regards,
Rolf
Thanks so much! That’d work perfectly.
