Chromecast Audio with Beolabs 8000: volume too loud
Over the weekend I played around and connected a Chromecast Audio to the line-in of BeoLab 8000’s. It works fine, but I have one question.When chromecasting from Deezer the volume is very loud. I can only set it to one or two ‘ticks’ when using my iPad volume controls. Streaming from Tune-in or Spotify is bit less loud.Is there a way to lower the volume so that I can better set the volume level?
Adjust it in the google home app.
Hello Leosgonewild,Thank you for your feedback.When looking into the Google Home app on an iDevice, I can select the Chromecast Audio. In the settings section I can adjust bass and treble, and select Dynamic Range on/off, but I don’t see any volume settings. Am I looking at the wrong place?Adjust it in the google home app.
Txs I found it. However, i can only go up to 10% and then it is already too loud. 🙁Isn’tthere a way to set the max volume?
Try turning of HDR. Or get one of these https://www.amazon.com/dp/B004P5MWFC/ref=cm_sw_su_dp
I changed the setup. I connected the BL’s to an old iPhone that I wasn’tusing anymore. In the iPhone you can set the maximum volume. Works perfectly!Try turning of HDR. Or get one of these https://www.amazon.com/dp/B004P5MWFC/ref=cm_sw_su_dp
