Choice of B and O Sub
Hi what’s the best combo with Beolab 18s? What’s the differences between the Beolab 2, Beolab 11 and Beolab 19 which one is the best sub? Thanks
Imo definitely the 19.
But as with all subs........very depending on the room/room size and the (right) placement - and what they are connected to.
If you preferedly use the setup for movies, you might consider the 2.
BL19 without any hesitation. Best sound with the most settings available.
The 19 matches the 18's - the BeoLab 2 matches the 8000's.
Personally I wouldn't mix these up.  B&O spend a LOT of time and effort matching speakers and subs (and speakers and systems) of the same era and always have done.
