Chassis change on BV7 MkII..
I'm having a chassis change on my BV7 MkII because of a sound problem.
Is there anything I should make sure is being done now the technichian is coming out anyway?
Will the SW be updated to the most recent version automatically with the chassis change?
Should I request any another updates?
Normally it is sent away for this to happen - I was without my TV for a month when my chassis was changed.
Yes, the SW will be updated. The sad thing is though, the panel won't be :(
No a chassis change is a on side job takes 1 - 2 H, you can't be sure it's the last SW but the same or newer.
Please post some pictures of the process.
Dario
The Stig is right, this is an onsite job. I'll try and snatch some photos.
So - do you recon I should request the SW to be updated then? The TV is about 1 yr old..
Yeah - shame the panel isn't changed... I can always hope the technician scr#w up and breaks it during the chassis change😜
If it's a 32" it would be better to get a HD KIT at the same time.
It's the 40" - so I'll ask for the latest SW and hopefully it'll be ready for the HDMI kit when that eventually comes out.
It's out πŸ™‚ 2:1 and 4:1
wow!!!... Is this the "official" B&O add-on??
 Or is it a 3rd party "un-official" gadget?
This is the one B&O official support.
