Hi Alls,
Recently my Beo 4 started to act very weirdly.You can see here:
/forum/general-discussion-and-questions/beo4-issues-what-are-the-odds
Second hand Beo4 are quite expensive but you can sometimes find ones with the LCD broken or leaking.
As mine is in good shape I started wondering if the LCD can be swapped and i found out, here on beoworld that it was easy.
But when i open the remote i can't remove the LCD without feeling i'm gonna broke something.
It look like glued or something, definitely a stronger bond than, say the LCD on a Beocom 6000 with came out easily.
This is the same with the plastic sheet where the key contacts are. can't manage to separate it from the PCB to clean it!
Any insight would be great. Thank you!
