Change the AM to FM by Beolink on Beomaster 6500
Hello,
How can I change the AM to FM on my Beomaster 6500 with Beolink (without TURN button), the shift + sound doesn't work.
thanks
Pavel
It should be SHIFT then SOUND, you don't press them together.
Thank you very much. It works, but Beomaster doesn't start to tune. I have Fm room antenna connected.
Pavel
If you mean "start" literally, then to begin scan/search-ing, you press > (or <) after pressing GOTO, on a Beolink 1000.  (GOTO also allows you to press 0-9 buttons to tune frequencies manually, rather than the presets you would normally get with 0-9 buttons.)
