Change ML/MCL converter startup volume
Is there any way to change the startup volume of a ML/MCL converter?
Press 'List' to display 'A-setup' then 'Go'.
Press 'List' again to display 'S-store' and then 'Go'
This will save the actual volumen/sound settings.
Note: maybe you will have to add 'S-store' to the 'List' of your Beo4 first.
Note 2: 'A-setup' allows you to change the bass, tremble, loudness as well.
I prefer, if present, a beolink 5000 with that. This way you can see the actual audiosettings.
Thank you for the info!
