Hello
i want to remove the dust cover of my cdx but I can t move the dust cover from the right hinge, it seem like glued, the left hinge slide out without problems. Do you have a idee to not broke anything by forcing too much?
regards
Hello
regards
I found how to remove it! Using wd40 on it, waiting 30min and it could slide out!
