CD5500 heat issue
Hi
I have a cd5500, everything is functioning, but the back left corner on the chassis gets pretty hot.
Inside is a "heatzink" with 2 pcs. 7805 voltage regs and a bd534 transistor. The surface temperature on heatzink meassured with an infrared termometer is 45 gr C. The plate is evenly hot.
Is this normal?
I tried to change electrolytics in the powersupply and the 2 7805 voltage regulators - no change….
baek47
Thanks Kim and Martin
Yes, I did change input mains to 240V.
I helped a bit but still the above temperatures.
Thanks for the good advice - always important to do this :- )
Also - I can hold my fingers on the heatzink, which many places is referred to as "ground rule".
Thanks for the advice Martin....
I will now listen with no worries to this great cd-player.....
baek47
