CD player for Beocenter 3500
Hi All. I own a Beocenter 3500 and would like to connect a CD player. Is this possible?
I saw a Beogram CD 3300 for sale but the DIN plug seems incompatible as far as I can see from a photo. The seller is not sure.
Someone also mentioned a Beogram CDX is possible but the one I found for sale is with RCA plugs. Or will that work with a RCA to DIN adapter?
Hopefully someone can help me out.
Thanks!
I found the solution already. Quite simple actually. The 2 data pins on the 7-pins DIN unscrew and then it fits into the 5-Pin socket. ;-)
Some Beocenter 3500 have both DIN and RCA sockets.
Yes I know, but mine doesn't have the RCA and speaker-in sockets. I have never found out why not all have the same. Maybe different per country? Mine is the later model with the black front
