Hi, does anyone know how to replace the lid belt on a CD 3500 . The lid will not open . Still plays the cd inside perfectly. Regards Martin Mawhinney.
CD 3500 lid belt replace
You have email.
Hi, Dillen, many thanks, trouble is the info is for the 3500 cassette player not the CD player. Martin
Which is why I wrote "which is very similar if you concentrate on the lid motor part."
The only thing you need to skip is the part covering the replacing of the belts in the cassettedrive.
I have re set up my beosystem 3500 All working but the remote won’t work the cd or the cassette functions, any answers Cheers Martin
Have you checked that the DIN plugs have all 7 pins present? If there are just 5 pins then then datalink commands cannot be sent to the CD or cassette.
