Can't work aux on BS9000
Hi guys, I am an happy owner of a beosound 9000 just bought yesterday.
appear to work perfectly
I connected it via coax cable to my amplifier
i bough also a 7pin din to jack adapter to can connect my ipod at the aux
but when I press the aux button (and aux appear on display) I don't have any audio
i also check disconnecting the coax cable and connecting my headphone
i check the connection of the din cable and are correct in input on pin 3 and 5
first banal question, it's the aux port the one of the 3 more far from link port?
there is anything to operate on the Keyboard?
i bough the din cable on Amazon looking for compatible with b&o
thanks a lot for any help
mario
Correct.
Nope.
Probably this is the trouble; you have purchased an Audio Aux *output* cable and not an *input* cable?
An easy way to test, if you have headphones with the same 3.5mm jack as your iPod: Play a CD on the 9000; plug your *headphones* into that Aux cable and see if you can hear it (may be a bit loud, but won't destroy anything).  (Or plug it into your analog amp input and see if that produces sound of the playing CD.)
Here is the pinout for A.Aux: Pin 1 = Left in, Pin 2 = Signal ground, Pin 3 = Left out, Pin 4 = Right in, Pin 5 = Right out, Pin 6 = Data (High > 3.5V, low < 0.8V), Pin 7 = Not used
Hi many thanks to answer also to other my questions.
in the description of the cable in amazon there is "to connect iPod, mo3 etc to b&o etc"
so I means to use as input, in any case I will try to arrange the test you suggest and I have an output cancel (but 5 pins) I can also test that.
Will update to you later about the the test
tanks
Taking the sound out of the coax on the 9000 will only give you sound from the CD’s....period!
Hi, I suspect that as I don't have also audio from the radio.
but in any case I tried via the headphones, with coax disconnected, I heard the cd and radio but not the aux :(
thanks
