Can’t play music through the app
Only thing that you don’t mentioned...
did you also try to restart the iDevices?
Indeed you have a ‘radio’ - that is built in to the Core and is TuneIN (a netradio provider).
It seems that you did not configure the Core, before you started to use it - and that the settings (some of these at least) are those from your dealer.
Can you airplay/cast to it?
Can you skip tracks etc with the remote?
Didn’t your dealer give you any instructions?
IMO you will have to reset it and start from scratch. This also means creating your own TuneIn account (+Deezer/Spotify.....) in order to have your own favorites.
Maybe I am wrong - best call your dealer to sort this out, ask him if resetting is ok.
Is that the unit, that you are going to keep?
If not, it might not be worth the efford to set it up with your own account/s and pairing rhe remote.
Maybe you can get an impression of the sound quality from listening to TuneIn in your own setup.
The Setup Guide can be found on the B&O homepage:
Try going to the app-settings page (in the upper right corner of the home screenn).
Go to “BeoLink” and make shure it is enabled.
Kudos Casperl - you’re the man 👍
