So, I temporarily have my BS9k hooked up directly to my BL5s, so that I can hear CDs.
But, the setup I'd *like* to use is to connect my BS9k to my Beolink Converter ML/NL (masterlink), then be able to select CD (Beolink Converter ML/NL) on my beosound core's inputs and control it though the beoplay app.
The problem is, when the BLC is connected to the BS9k through masterlink, I can't seem to control the CD player. Selecting the CD input from the BLC in the Beoplay app doesn't turn on the BS9k from standby, for instance.
Selecting the CD (Beolink Converter ML/NL) input from the BS Core (in the Beoplay app) also fails to turn on the BS9k from standby.
The BLC is configured to be ML Enabled, V Master.
I'm pretty sure the BS9k is set A Opt 0 but i'll double check that tomorrow. Any other suggestions?
