Cannot rename Essence MK2
Hello BeopeepsI cannot rename my essence MK2 in the app, when i try it says i need to open the apple home app and do it in there.I cannot find it in the apple app eitherDeleted the product and added again but nothing well let me change it from “kitchen” Any idea? Login to view image
That is funny!
I just looked at my Essence MK2.....no problem there.
This is a general issue, when you have added your airplay 2 speaker to the apple home kit app. I’ve had the same problem when trying to rename a M5 speaker. I had to remove it from the home kit app before I could rename it in the Bang & Olufsen app.Hello Beopeeps I cannot rename my essence MK2 in the app, when i try it says i need to open the apple home app and do it in there. I cannot find it in the apple app either Deleted the product and added again but nothing well let me change it from “kitchen” Any idea? Eclipse 65 V1-32 Beosound M5 Essence MK2 BLI
Best regards
Dyssegaard
Dyssegaard
Thanks Dyssegaard for the explanation.
Obviously I don’t use the Apple Home Kit app.
Strange problem, thank you i found it in favs, removed and renamed.
You could try it with the BeoTool app iOS
