Cannot rename Essence MK2
Hello Beopeeps
I cannot rename my essence MK2 in the app, when i try it says i need to open the apple home app and do it in there.
I cannot find it in the apple app either
Deleted the product and added again but nothing well let me change it from “kitchen”
Any idea?
That is funny!
I just looked at my Essence MK2.....no problem there.
Seanie_230 wrote:
Hello Beopeeps
Any idea?
Eclipse 65 V1-32 Beosound M5 Essence MK2 BLI
This is a general issue, when you have added your airplay 2 speaker to the apple home kit app.
I’ve had the same problem when trying to rename a M5 speaker.
I had to remove it from the home kit app before I could rename it in the Bang & Olufsen app.
Best regards
Dyssegaard
Thanks Dyssegaard for the explanation.
Obviously I don’t use the Apple Home Kit app.
Strange problem, thank you i found it in favs, removed and renamed.
You could try it with the BeoTool app iOS
