Emil Jensen wrote:
I would recommend trying buying on Itunes,
Almost same quality, but much cheaper and much faster and convenient
iTunes streamed 4K will never hit the bitrate of a Blu-ray 4K.
"Overall, Apple TV+ streams at approximately half that of a UHD Blu-ray disc"
That's fairly significant. On top of this, the audio quality doesn't get close to a Blu-ray. You get uncompressed audio from a Blu-ray!
Lastly, iTunes 4K is approximately 8GB. A Blu-ray 4K DVD is usually 66GB! And those extra GBs is the uncompressed audio. I agree that the image quality won't differ too much from the disc version, but the audio is hugely different.
You cannot beat the raw data from a Blu-ray or UHD Blu-ray disc. The entire point of spending the big bucks on these top-of-the-range TVs is that we get the best experience on the market. Not compromise to save a few bucks or hassle. Hence the reason for asking for a UHD player recommendation!
Obviously the big downside of 4K UHD discs is the cost. Some are incredibly priced. You can buy a Blu-ray discounted for £5 and the UHD version is still £20!
But on the flipside, so many films are still not streaming in 4K on iTunes - things like Django Unchained or Hateful Eight. All available on UHD, but HD-only as a stream.
