Can you lock the doors on a Beosound Ouverture?
Should this work with Beosound 3000?
Somehow I cannot get the glass doors locked.. I'm using Beo4. and I have added SHIFT command to under list function.
this is how I've tried that:
1. select SHIFT from list and press GO
2. type 9 0 3 9 6
3. usually nothing happens. but if there is some other functions added inder list, it activates that function. or if I used radio/aux/cd before selecting shift system turns on and starts using that function when pressing GO..
Please help me, my 10 months old daughter is too interested about those magic glass doors 🙁
if this is not ment to work with Beosound 3000. is it possible to cover the IR sensors with black tape etc to prevent doors opening? (I use small piece of transparent tape to 'lock' my beogram 7000 dust lid)
Thanks in advance!
Try selecting SHIFT with LIST. Then 9 0 3 6 9. Don't press GO.
Yes, it should work with a BS3000. Works on my BS3200. Good luck!
Cheers,
Matthew
