Can you fit an Apple TV 4K in the rear of an Avant 55 NG?
My parents have bought an Avant 55 NG. I’ll give them a Apple TV 4K to go with it - but can it be installed in the rear or does it need to be hidden in a cabinet?
No. It’s too thick to fit.
It fits the earlier model.
But even still it’s better not to fit one there because it may overheat anyway.
You can put it in a cabinet or alternatively you can get the bracket from sTB
Or even still what about sticking the bracket you can buy from the Apple store on the back ? You will also need a PUC cable for it too to use it with the beoremote one.
I had an Avant NG and Apple TV 4K and it fit no problem inside the back of the cabinet.
