Hi everyone,
I've been working on a project in recent months and I think that I have found a way to improve on the standard Powerlink wiring format. I'm happy with the results on my own speakers, but I would be interested to hear the thoughts of other Beoworlders as to whether normal Powerlink cable is good enough for high-end audio listening, or whether there is room for improvement.......
I've found that by completely re-working the wiring arrangement, the speaker performance can be improved and some of the inherent issues that often seem to affect B&O audio systems can be removed or greatly reduced.
The result is a completely different cable design which seems to give a quieter noise floor, reduced signal loss and improved treble response.
My aims were as follows:-
The final version of the cable has a 3.4mm outer diameter (so not too bulky when compared to traditional Powerlink) and ditches 8 pin DIN plugs for 7 pin versions to allow a higher quality plug (with solid metal body and gold pins) to be used. There are now only 3 wires inside the cable instead of 8, but this works correctly on all Beolab speakers except Beolab 5.
When used with older speaker that have displays fitted (eg. Beolab 5000, Penta, etc), the speakers work correctly, but the cables are designed not to light up the displays (to avoid inducing data pulses into the audio channels). Each cable carries only one audio channel (ie. left or right, not both), so the cables are designed not to be daisy-chained.
My listening room now uses these cables running a pair of Beolab Penta 3's and I'm very happy with the results. I would be interested to hear your thoughts on my latest project! ❓
