Can one connect a BC2 and a BM5 in order to get Net radio and Net Music, without a videomaster?
And if so, what would the option programming look like?
As the BeoMaster 5 units are quite prone to dying and being discarded since the repairs are too costly, there should be an availability of BeoSound 5 control units at good prices.
Hi BarryThe obvious answer to your question is yes, with a cable (from Soundsheavenly) going from the line output of the BM5 to the line input of the BC2.But if your goal is just Internet radio, there are smaller devices to do it!Chromecast Audio is a solution, if you can find one...I use this (the smallest I found with physical buttons) Login to view image
