Yes I believe soThis is mine. If I don’t ude the integreted, will then the multiroom work?
Can not see my BS Essence at Bang & Olufsen app
Yes, it will.
The main purpose of the "integration" is to let the system know if you have e.g. a BeoVision Avant and a Moment in the living room, that are integrated since the speakers are only connected to the BeoVision. If you are listening on a different device in your home, and would like the living room to join by using the app, the system/app will know that both the Moment and the BeoVision will have to be active. The new range of BeoVision's are a bit different (currently only the Eclipse) since the Core is built into the TV. There will be plenty of confusion over this theme😁
Roger
Ahhhhhhhhhh 💡The new range of BeoVision's are a bit different (currently only the Eclipse) since the Core is built into the TV.
I have tried to change the first one to none (as seen on my danish screen shot) Did not make any difference. And have restarted app, essence and beolink converter.
Dear Master123456789,a simple restart won’t work (as I explained above). Please try a factory reset on booth devices and do the configuration again - without activating the integration settings. Cheers BeroliI have tried to change the first one to none (as seen on my danish screen shot) Did not make any difference. And have restarted app, essence and beolink converter.
